<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Poly or OEM Rubber?]]></title><description><![CDATA[<p dir="auto">hey guys i am going to be ordering new control arms in the next week or 2 and was curious if I should get factory rubber m3 offset CAB's or Poly M3 offset CAB's. the car is on billie sports with vogtland springs currently but i am going to be buying fresh billie sportys and H&amp;R races. i would like to get into tracking the car next year once the suspension and other odds and ends are sorted out. Will poly bushings be too harsh for street use on our fine Milwaukee streets as the car serves as a DD in the summer. Input from you guys would be much appreciated! Thanks</p>
]]></description><link>https://wibimmers.com/topic/1583/poly-or-oem-rubber</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 08:17:57 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/1583.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 21 Jun 2013 22:52:54 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Poly or OEM Rubber? on Sat, 22 Jun 2013 20:19:40 GMT]]></title><description><![CDATA[<p dir="auto">idk about either.</p>
<p dir="auto">but your guy's avatars are like the same, but not the same.</p>
]]></description><link>https://wibimmers.com/post/24387</link><guid isPermaLink="true">https://wibimmers.com/post/24387</guid><dc:creator><![CDATA[KaiserRolls]]></dc:creator><pubDate>Sat, 22 Jun 2013 20:19:40 GMT</pubDate></item><item><title><![CDATA[Reply to Poly or OEM Rubber? on Sat, 22 Jun 2013 01:20:02 GMT]]></title><description><![CDATA[<p dir="auto">yes, definitely, esp. on monday evening on your way back from work since im not too far from your work.</p>
]]></description><link>https://wibimmers.com/post/24368</link><guid isPermaLink="true">https://wibimmers.com/post/24368</guid><dc:creator><![CDATA[B C]]></dc:creator><pubDate>Sat, 22 Jun 2013 01:20:02 GMT</pubDate></item><item><title><![CDATA[Reply to Poly or OEM Rubber? on Sat, 22 Jun 2013 00:33:00 GMT]]></title><description><![CDATA[<p dir="auto">Snap, when i get the tie rods on next week we should meet up in the evening!</p>
]]></description><link>https://wibimmers.com/post/24367</link><guid isPermaLink="true">https://wibimmers.com/post/24367</guid><dc:creator><![CDATA[andyhundley]]></dc:creator><pubDate>Sat, 22 Jun 2013 00:33:00 GMT</pubDate></item><item><title><![CDATA[Reply to Poly or OEM Rubber? on Fri, 21 Jun 2013 23:57:50 GMT]]></title><description><![CDATA[<p dir="auto">I have 85 Shore A rear bushings. They are not at all harsh. I wish I would have gone stiffer. As for the front. whatever you get, get offset. I believe Treehouse racing has a delrin offset bushing. I have M3 offset now. It is very cozy, I can handle more harshness and will probably step it up a notch when these wear out. You will have to drive my car and see if its too soft/harsh for you</p>
]]></description><link>https://wibimmers.com/post/24364</link><guid isPermaLink="true">https://wibimmers.com/post/24364</guid><dc:creator><![CDATA[B C]]></dc:creator><pubDate>Fri, 21 Jun 2013 23:57:50 GMT</pubDate></item></channel></rss>
