<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[AFR gauge / Wideband]]></title><description><![CDATA[<p dir="auto">Hi friends, </p>
<p dir="auto">Anyone have one of these that I can borrow when I install my engine? This will be installed just to make sure my baseline is okay until I go to the dyno ... thought I would give it a shot .. </p>
<p dir="auto">Thanks</p>
]]></description><link>https://wibimmers.com/topic/1559/afr-gauge-wideband</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 07:33:57 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/1559.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 12 Jun 2013 18:57:53 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to AFR gauge / Wideband on Thu, 13 Jun 2013 17:28:31 GMT]]></title><description><![CDATA[<p dir="auto">Agreed with running narrowband and wideband. Simulated narrowband will piss off Motronic when it sees a voltage slightly higher or lower or higher than expected (some ECUs operate from 0.1V to 1.1V and some sensors read 0.0V to 1.0V  etc)  and you will get a CEL. </p>
<p dir="auto">I really hope the W.A.R. chip setup works phenomenally for you but if you end up springing for Megasquirt you will definitely want a wideband setup.</p>
]]></description><link>https://wibimmers.com/post/24070</link><guid isPermaLink="true">https://wibimmers.com/post/24070</guid><dc:creator><![CDATA[B C]]></dc:creator><pubDate>Thu, 13 Jun 2013 17:28:31 GMT</pubDate></item><item><title><![CDATA[Reply to AFR gauge / Wideband on Thu, 13 Jun 2013 17:19:47 GMT]]></title><description><![CDATA[<p dir="auto">I second that for the innovate Lc-1.. I didnt like the narrow band simulation though so i recommend using both with two bungs welded.. one for the the ecu and one for just afr readings..</p>
]]></description><link>https://wibimmers.com/post/24068</link><guid isPermaLink="true">https://wibimmers.com/post/24068</guid><dc:creator><![CDATA[bimmer82]]></dc:creator><pubDate>Thu, 13 Jun 2013 17:19:47 GMT</pubDate></item><item><title><![CDATA[Reply to AFR gauge / Wideband on Thu, 13 Jun 2013 16:05:11 GMT]]></title><description><![CDATA[<p dir="auto">Innovate LC1. Very good bang for the buck now. When I bought one and they came out, they were still priced well.</p>
]]></description><link>https://wibimmers.com/post/24057</link><guid isPermaLink="true">https://wibimmers.com/post/24057</guid><dc:creator><![CDATA[Earl]]></dc:creator><pubDate>Thu, 13 Jun 2013 16:05:11 GMT</pubDate></item><item><title><![CDATA[Reply to AFR gauge / Wideband on Thu, 13 Jun 2013 14:02:22 GMT]]></title><description><![CDATA[<p dir="auto">I just don't really see the long term need for it as I am NA but maybe you are right ... recommendations ??</p>
]]></description><link>https://wibimmers.com/post/24045</link><guid isPermaLink="true">https://wibimmers.com/post/24045</guid><dc:creator><![CDATA[merl]]></dc:creator><pubDate>Thu, 13 Jun 2013 14:02:22 GMT</pubDate></item><item><title><![CDATA[Reply to AFR gauge / Wideband on Thu, 13 Jun 2013 03:39:23 GMT]]></title><description><![CDATA[<p dir="auto">they are nice to have just to keep an eye on things</p>
]]></description><link>https://wibimmers.com/post/24035</link><guid isPermaLink="true">https://wibimmers.com/post/24035</guid><dc:creator><![CDATA[Jeff]]></dc:creator><pubDate>Thu, 13 Jun 2013 03:39:23 GMT</pubDate></item><item><title><![CDATA[Reply to AFR gauge / Wideband on Wed, 12 Jun 2013 23:14:52 GMT]]></title><description><![CDATA[<p dir="auto">Why not just purchase one so you have it in the long run and can always know that it is fine?</p>
<p dir="auto">200 bucks is not the worst thing in the world</p>
]]></description><link>https://wibimmers.com/post/24028</link><guid isPermaLink="true">https://wibimmers.com/post/24028</guid><dc:creator><![CDATA[GunMetalGrey]]></dc:creator><pubDate>Wed, 12 Jun 2013 23:14:52 GMT</pubDate></item></channel></rss>
