<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[e38 blower motor DIY]]></title><description><![CDATA[<p dir="auto">This is a diy on removing replacing and testing the blower motor on a 1995 bmw 740il. it takes about 2 hours to remove test and put it back together. </p>
<p dir="auto"> Tools you will need:</p>
<p dir="auto">13mm socket</p>
<p dir="auto">10mm socket</p>
<p dir="auto">ratchet</p>
<p dir="auto">t10 torx</p>
<p dir="auto">t20 torx</p>
<p dir="auto">t25 torx</p>
<p dir="auto">flat screwdriver</p>
<p dir="auto">phillips screwdriver</p>
<p dir="auto">19mm socket</p>
<p dir="auto">pliers</p>
<p dir="auto">volt meter </p>
<ol>
<li>
<p dir="auto">remove the 4--13mm bolts on each end of the dash</p>
</li>
<li>
<p dir="auto">remove the 4 screws in the top side of the glove box</p>
</li>
<li>
<p dir="auto">remove the 6 plastic nuts from the trim above the glove box</p>
</li>
</ol>
<p dir="auto"><img src="http://i1147.photobucket.com/albums/o544/ljx124/1995%20740il/diy%20photos/740ilblowermotordiy2.png" alt="740ilblowermotordiy2.png" class=" img-fluid img-markdown" /></p>
<ol start="4">
<li>
<p dir="auto">remove the trim on the a pillars </p>
</li>
<li>
<p dir="auto">remove the 4 t20 screws from the dash there is one on each side of the radio and one on each a pillar </p>
</li>
<li>
<p dir="auto">pry the passenger side airbag cover and unbolt the passenger side air bag 4--10mm nuts</p>
</li>
<li>
<p dir="auto">remove the gauge cluster there is 2--t10 screws on the top of it that hold it in</p>
</li>
<li>
<p dir="auto">remove the headlight and fog light switch pull the knobs off and there is a 19mm plastic nut to remove</p>
</li>
</ol>
<p dir="auto"><img src="http://i1147.photobucket.com/albums/o544/ljx124/1995%20740il/diy%20photos/740ilblowermotordiy1.jpg" alt="740ilblowermotordiy1.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">you can now take the top of the dash out of the car.</p>
<p dir="auto"><img src="http://i1147.photobucket.com/albums/o544/ljx124/1995%20740il/diy%20photos/740ilblowermotordiy3.jpg" alt="740ilblowermotordiy3.jpg" class=" img-fluid img-markdown" /></p>
<ol start="9">
<li>
<p dir="auto">there is 2 plastic arms that you have to take off. the top arm unclips from the vent box  on both sides. the lower arm pulls out of the vent box on the left side and unclips on the right side.</p>
</li>
<li>
<p dir="auto">unplug the blower motor and remove the 4--t20 screws from the cover over the blower motor</p>
</li>
<li>
<p dir="auto">remove the blower motor. there is 3--t25 screws that hold the blower motor in. </p>
</li>
</ol>
<p dir="auto"><img src="http://i1147.photobucket.com/albums/o544/ljx124/1995%20740il/diy%20photos/740ilblowermotordiy4.jpg" alt="740ilblowermotordiy4.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">if the blower motor is good you should have 1.8 ohm's between the hot and neutral wires ( red and blue). you can also test for voltage at these wires you should have 3.8v when it is starting. the voltage will rise with fan speed. the 3.8 volts is only to start the blower motor.</p>
<p dir="auto"><img src="http://i1147.photobucket.com/albums/o544/ljx124/1995%20740il/diy%20photos/740ilblowermotordiy7.jpg" alt="740ilblowermotordiy7.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">you can check the resistance on the blower motor resistor also. you should have 1.4ohm's on the hot and neutral pins. you can test the voltage going in to the resistor should be 12 volts. to can test this on the 2 big wires on the plug ( brown is neutral and yellow red is hot) the key must be on and battery connected.</p>
<p dir="auto"><img src="http://i1147.photobucket.com/albums/o544/ljx124/1995%20740il/diy%20photos/740ilblowermotordiy6.jpg" alt="740ilblowermotordiy6.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">if both check out good (witch this was the problem on mine) you can try to lube the bearings on the blower motor it self.<img src="http://i1147.photobucket.com/albums/o544/ljx124/1995%20740il/diy%20photos/740ilblowermotordiy5.jpg" alt="740ilblowermotordiy5.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">luge the bearings using a drop of oil or lithium grease. do not over oil the bearing's or you may burn out the blower motor. then test the blower motor before you reinstall it.</p>
<p dir="auto">you can test it  by attaching a wires to the hot and neutral ( red and blue) to a car battery. the red one is the positive and the blue is the negative. you will know right away if it is good or bad.</p>
<p dir="auto">installation is reverse of the removal. the only problem i had was getting the dash pad back in the foam kept getting in my way.</p>
<p dir="auto">this saved me some money and glad i did not have to replace either parts. any other question's just ask. this is my first time posting a Diy so let me know if i need to change or add something.</p>
]]></description><link>https://wibimmers.com/topic/1389/e38-blower-motor-diy</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 05:46:46 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/1389.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 19 Apr 2013 00:00:26 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to e38 blower motor DIY on Mon, 29 Apr 2013 17:26:53 GMT]]></title><description><![CDATA[<p dir="auto">Great write up!  Just did mine on my E39... not nearly as labor intensive though.  Props for a detailed DIY.</p>
]]></description><link>https://wibimmers.com/post/22225</link><guid isPermaLink="true">https://wibimmers.com/post/22225</guid><dc:creator><![CDATA[Mott Power]]></dc:creator><pubDate>Mon, 29 Apr 2013 17:26:53 GMT</pubDate></item><item><title><![CDATA[Reply to e38 blower motor DIY on Fri, 19 Apr 2013 05:04:02 GMT]]></title><description><![CDATA[<p dir="auto">Even though you will never finish your car Jeff,</p>
<p dir="auto">this write-up is top-notch</p>
<p dir="auto"><img src="/assets/uploads/files/emoticons_default_wink.png" alt=";)" class=" img-fluid img-markdown" width="20" height="20" /></p>
]]></description><link>https://wibimmers.com/post/21628</link><guid isPermaLink="true">https://wibimmers.com/post/21628</guid><dc:creator><![CDATA[KaiserRolls]]></dc:creator><pubDate>Fri, 19 Apr 2013 05:04:02 GMT</pubDate></item><item><title><![CDATA[Reply to e38 blower motor DIY on Fri, 19 Apr 2013 03:33:14 GMT]]></title><description><![CDATA[<p dir="auto">actually it really wasn't all that bad. i was told it would take 7 hours to do and it only took 2. the most fun part was finding all the screws and making sure i remembered where it all went.</p>
]]></description><link>https://wibimmers.com/post/21616</link><guid isPermaLink="true">https://wibimmers.com/post/21616</guid><dc:creator><![CDATA[Jeff]]></dc:creator><pubDate>Fri, 19 Apr 2013 03:33:14 GMT</pubDate></item><item><title><![CDATA[Reply to e38 blower motor DIY on Fri, 19 Apr 2013 02:58:42 GMT]]></title><description><![CDATA[<p dir="auto">That looked like hell. Pulling anything dash related is hellacious.</p>
]]></description><link>https://wibimmers.com/post/21609</link><guid isPermaLink="true">https://wibimmers.com/post/21609</guid><dc:creator><![CDATA[Brian.]]></dc:creator><pubDate>Fri, 19 Apr 2013 02:58:42 GMT</pubDate></item><item><title><![CDATA[Reply to e38 blower motor DIY on Fri, 19 Apr 2013 01:29:44 GMT]]></title><description><![CDATA[<p dir="auto">This is a very well done writeup! It doesn't look like a very fun job, but this tutorial makes it look pretty painless.</p>
]]></description><link>https://wibimmers.com/post/21602</link><guid isPermaLink="true">https://wibimmers.com/post/21602</guid><dc:creator><![CDATA[B C]]></dc:creator><pubDate>Fri, 19 Apr 2013 01:29:44 GMT</pubDate></item><item><title><![CDATA[Reply to e38 blower motor DIY on Fri, 19 Apr 2013 00:37:57 GMT]]></title><description><![CDATA[<p dir="auto">Jeff, how about you put your car back together and give everyone rides dammit</p>
]]></description><link>https://wibimmers.com/post/21597</link><guid isPermaLink="true">https://wibimmers.com/post/21597</guid><dc:creator><![CDATA[KaiserRolls]]></dc:creator><pubDate>Fri, 19 Apr 2013 00:37:57 GMT</pubDate></item><item><title><![CDATA[Reply to e38 blower motor DIY on Fri, 19 Apr 2013 00:26:46 GMT]]></title><description><![CDATA[<p dir="auto">Good job Jeff;) I will hit you up if I ever need to pull my dash.</p>
]]></description><link>https://wibimmers.com/post/21596</link><guid isPermaLink="true">https://wibimmers.com/post/21596</guid><dc:creator><![CDATA[Earl]]></dc:creator><pubDate>Fri, 19 Apr 2013 00:26:46 GMT</pubDate></item></channel></rss>
