  3. Local Scene
  4. Dent removal, general cleaning and buffing Spring GTG
65 Posts 19 Posters 1.3k Views 2 Watching
    wasnt m3 said:
    Yes, I do have a fender roller.
    Where are you located? And how much do you charge? I will need to get mine rolled eventually, and also my friend needs his wrx rolled.
      I'm in the waukesha area. Tool is available for rent, $40 plus deposit. Not really looking to do the rolling for other people's cars.
      • C
        C
        Chadley
        Great. I need to roll the fenders on my dually :)
        • AvusHatesConesA
          AvusHatesConesA
          AvusHatesCones
          This sounds like fun meet, I'll try to make it out, but I'll be preparing everything to move the following weekend. Either way, I STILL need to get a hold of TJ's guy for the dent removal... Door dings suck
          Silver Grey E46 M3
          • e36mpwrE
            e36mpwrE
            e36mpwr
            I got a quick question as someone told me to try brake fluid on my tires they will stay clean (which they did and shined because I saw his and mine then) when I was driving some was splattering on my paint what can I use to take it off?
              That someone is a dick. Brake fluid eats paint.
              • e36mpwrE
                e36mpwrE
                e36mpwr
                W O W, can I use anything to take that of now or what?
                  I am not the expert detailer, but unless you hear anything better, I would probably wash it with dish soap to help strip the oil off, claybar, then re-wash with good car wash soap then wax.
                  • e36mpwrE
                    e36mpwrE
                    e36mpwr
                    Ill give it a try tomorrow I left it outside tonight so it can get wet from the rain :( and then washing it my self soap water dry it off wax it take it to a car wash soap water their being it back and hope it's off. Haah
                      There may not be a lot of clear or paint left to wash, as wasntm3 said, it EATS paint, that means it wrecks it, breaks it down chemicly
                        I used silicone based tire shine. It doesn't dry out the rubber like the ones with alcohol. You're clearcoat is probably being eaten there. That is why is is yellowish:/ I would try to wash it and then a claybar, or buff it out.
                        • e36mpwrE
                          e36mpwrE
                          e36mpwr
                          Ill try and clear it out as much as I can because I have to take it to a body shop any ways to fix a little rust and have him do that too
                          • K
                            K
                            krautuner
                            next Saturday guys..see you then!
                            e2526838-2d06-47c6-87b1-e8cf6c8c570ezps
                              I haven't seen a time/address for this yet.
                              • K
                                K
                                krautuner
                                I'm at 4920 South Hawthorne Drive NB 53151
                                from 10am till late afternoon
                                • K
                                  K
                                  krautuner
                                  Gentlemen, I'm really considering rescheduling this event. The extended forecast looks like more of the same cold crappy weather.
                                  Thoughts????
                                    fine by me if it doesnt look to be good weather
                                      I would not mind that=)
                                      • K
                                        K
                                        krautuner
                                        OK, I will look at my calender and see what I can do in the next couple of weeks.
                                        I'm not asking for much just sunny and seventy but that seems like a lot these days!
                                        • M
                                          M
                                          Mott Power
                                          That would be great if it can be moved, I've had a personal matter come up that might obscure me from attending.  And the weather is underwhelming to say the least.
