<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[overheating issue]]></title><description><![CDATA[<p dir="auto">I have me a 97 528i</p>
<p dir="auto">And just 2 days ago i was sitting at the railroad light waiting foe a train to pass and my temp gauge went up to the next line</p>
<p dir="auto">Once i started driving it went back to normal.</p>
<p dir="auto">The next day i went to the car wash waiting for my turn and it went all the way up to the red with the red light on</p>
<p dir="auto">The fan clutch seems to be fine its not wobbly</p>
<p dir="auto">I did the newspaper test and it was ok</p>
<p dir="auto">What else should i check or look for to solve this issue?!?!</p>
]]></description><link>https://wibimmers.com/topic/1285/overheating-issue</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 04:52:15 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/1285.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 22 Mar 2013 15:18:46 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to overheating issue on Sat, 06 Apr 2013 06:53:44 GMT]]></title><description><![CDATA[<p dir="auto">If your fan is working properly and make sure it is not loose and it has some tention to it when you spin it. Check that your coolant is topped off best time to do it is before you start the car in the morning when it has sat for a while. If your coolant is full then change your thermostat.</p>
<p dir="auto">It sounds to me more like a thermostat or low coolant. Seeing as when you sit it gets hot and when you move it is normal.</p>
]]></description><link>https://wibimmers.com/post/20077</link><guid isPermaLink="true">https://wibimmers.com/post/20077</guid><dc:creator><![CDATA[Jeff]]></dc:creator><pubDate>Sat, 06 Apr 2013 06:53:44 GMT</pubDate></item><item><title><![CDATA[Reply to overheating issue on Sat, 06 Apr 2013 06:02:02 GMT]]></title><description><![CDATA[<p dir="auto">Check the fan clutch same thing happened to me. Keep the car off and open the hood and spin the fan if it's loose the fan clutch is out.</p>
]]></description><link>https://wibimmers.com/post/20070</link><guid isPermaLink="true">https://wibimmers.com/post/20070</guid><dc:creator><![CDATA[e36mpwr]]></dc:creator><pubDate>Sat, 06 Apr 2013 06:02:02 GMT</pubDate></item><item><title><![CDATA[Reply to overheating issue on Fri, 22 Mar 2013 20:50:58 GMT]]></title><description><![CDATA[<p dir="auto">My 530 did that when the thermostat was acting up too. Fix it now, and don't sit and idle it if you know there is a problem unless you want to put a new motor in there.</p>
]]></description><link>https://wibimmers.com/post/18884</link><guid isPermaLink="true">https://wibimmers.com/post/18884</guid><dc:creator><![CDATA[240sxguy]]></dc:creator><pubDate>Fri, 22 Mar 2013 20:50:58 GMT</pubDate></item><item><title><![CDATA[Reply to overheating issue on Fri, 22 Mar 2013 20:25:09 GMT]]></title><description><![CDATA[<p dir="auto">Check the thermostat, mine recently went out and would fluctuate oddly like that as well.</p>
]]></description><link>https://wibimmers.com/post/18881</link><guid isPermaLink="true">https://wibimmers.com/post/18881</guid><dc:creator><![CDATA[Mott Power]]></dc:creator><pubDate>Fri, 22 Mar 2013 20:25:09 GMT</pubDate></item><item><title><![CDATA[Reply to overheating issue on Fri, 22 Mar 2013 15:57:58 GMT]]></title><description><![CDATA[<p dir="auto">My thermostat has been bad and it does the same thing. It starts to get warmer when sitting, but not always. It could be a bad waterpump too? I know they came with a plastic impeller stock. That could have broken, leaving it to move water slower while at idle, versus under a load. Just a thought</p>
]]></description><link>https://wibimmers.com/post/18854</link><guid isPermaLink="true">https://wibimmers.com/post/18854</guid><dc:creator><![CDATA[Earl]]></dc:creator><pubDate>Fri, 22 Mar 2013 15:57:58 GMT</pubDate></item><item><title><![CDATA[Reply to overheating issue on Fri, 22 Mar 2013 15:36:41 GMT]]></title><description><![CDATA[<p dir="auto">It definitely sounds fan related but if you are confident that the fan is working...</p>
<p dir="auto">... Ensure you are running proper coolant (50/50 mix). Bleed the cooling system, spray your radiator and AC condenser to clean out bugs and dirt that may be blocking the passages, run Redline Water-Wetter, check water pump belt tension, consider replacing water pump  and thermostat if you are uncertain of when it was last done.</p>
]]></description><link>https://wibimmers.com/post/18848</link><guid isPermaLink="true">https://wibimmers.com/post/18848</guid><dc:creator><![CDATA[B C]]></dc:creator><pubDate>Fri, 22 Mar 2013 15:36:41 GMT</pubDate></item></channel></rss>
