  3. Local Scene
  4. WiBimmers Lake Meet Kinda of Thing... Or Whatever
71 Posts 12 Posters 1.2k Views 1 Watching
  • I
    I
    industrialsized
    my cabbie is more lowz than any of you could dream and would have had no problems on that track
    church!
    • The Full BananaT
      The Full BananaT
      The Full Banana
      you just admitted to owning a vw cabrio on the internet. uh oh!
      that's a coming out of sorts
      • StewCrewS
        StewCrewS
        StewCrew
        Also implying you have the lowest car ever, in the history of the world. I can dream a pretty low car ;)
        If you stayed to the outside, no matter how low you are you would have been fine. That's all it really was.
          It's not very hard to have a very low car! Air ride you can put your subframe in the ground easy. And it's not terribly expensive.
            We are talking about static here Rowley. lol And a proper air ride setup costs $2000. That's with piecing it together and building your own struts. If you buy premade struts, those are usually $1000 + for just the fronts=)
            • Brian.B
              Brian.B
              Brian.
              rampelsauce said:
              Brian's car could use a bit of a drop even to catch up with Tom. That would make for a sweet pic with two cars at the same ride height. Volvo vs BMW tandem drift. You down Brian?
              Zach, you don't realize how low my car is do you? I tuck 15" rims... Frame rails are about 1.5" off the ground, my oil pan is less.
              instagram @howdoyoudrivethat
              • Brian.B
                Brian.B
                Brian.
                Air ride is expensive no matter how you look at it. An static low is way cooler then bagged. I've had both. So Don't question meh!
                • Brian.B
                  Brian.B
                  Brian.
                  Also, I'm not trying to sound like an asshole with this whole "my car is stupid low guys, you just don't realize it". It's just online pictures, don't do it justice...
                    You know you can edit posts right Brian? lol
                      And a proper set of coils? $1500 at least. So it's really not terribly expensive. And if you have manual controls it can be done for 1000$ if you can fab your front struts.
                      • Brian.B
                        Brian.B
                        Brian.
                        Actually any set of coil overs is proper. You can get stance coils for 900$ and those are far more then what you'd ever need. Just saying. yes, they make 35 way adjustable coilovers. But let's be honest here. None of you track your car or drift it to the point where you'd need that. Manual controls on air ride is gay btw. And hasn't been used in years.
                          people use manual all the time for budget setups. I would spring the extra cash and get decent management. Manual setups have a lot more room for leaks and issues.
                          • Brian.B
                            Brian.B
                            Brian.
                            Manual's suck ass in general. Also, Earl. Editing posts is for weaklings.
                            • StewCrewS
                              StewCrewS
                              StewCrew
                              Eh, the 35 way adjustable is real nice to have. I have 3 sets of numbers I use on my BC's. One for roads if I'm slammed, one for roads for when I'm raised a bit, and one for the track. And it really is a noticeable difference. It's crazy what a few clicks can do.
                              • Brian.B
                                Brian.B
                                Brian.
                                35 way adjustable is too much. Not for a car that gets street driven.
                                  It works for Jake though since it doubles as a track car. It makes the ride more comfortable, and allows you to have a very refined setting at the track=)
                                  And I meant that you could edit so instead of posting three times, you just put it all in one=D
                                  • Brian.B
                                    Brian.B
                                    Brian.
                                    nah dude. No editing. For weaklings.
                                    Posted Image
                                      Manual air ride- non adjustable coils. E-management-adjustable coils. Not saying that they are comparable in ride quality or anything, but in their separate markets they kind of compare.
                                        I'm not sure why you're stating adjustable and non-adjustable coils for....you're confusing me. You can put a bag on any strut/coil and use either manual or digital management. All digital management does is uses electrical switches to operate a solenoid. In a manual system, you're literally manually managing the air.
                                        • StewCrewS
                                          StewCrewS
                                          StewCrew
                                          This. 8 up front and 10 in back is as soft as I go, which is when the coils are raised. Thats comfy as hell, but not as low as Id like. 12 front 15 back is good for being low and stiff, but not too stiff where youre bouncing everywhere like cut springs, and not too soft where your oil pan is saying "hi" to every bump. Anything higher than that has worked wonders for me at le track.
