chit chat thread
Probably about 6 cans worth of snorting. It appears that it is possible to get it out without dropping the cradle/engine/trans assembly together but it looks easier to drop it all together.
To take this in a different direction it appears that an e153 transmission used in Camry's bolts to the 3mz engine... Cross referencing axle shafts it appears that the splines are the same and the dimensions are almost identical between Auto and manual transmissions. And the splines and critical dimensions of the 2nd gen Sienna driveshafts are the same, just the outboard part is longer because the vehicles got wider. So that would lead me at this point to think I could use my existing axle shafts. I need to do a little more research on that but it doesn't appear to kill the idea.
Other problems I am not worried about: routing shifter cables, fabricate shifter in the console, clutch pedal and master cylinder.
Problems I AM worried about: ECU freaking out with no auto transmission. I have seen solutions (none in a sienna) ranging from ground a certain pin, presumably telling the ECU that the transmission is in neutral, to using a 1MZ ECU/electronics/intake manifold (that loses the VVTi) I saw some swaps of the 3MZ and e153 transmission into MR2s which would be pretty awesome.
Why would I manual swap a Sienna? I am crazy.
This van is an '04 with 172k, I got it for $2200 because the transmission didn't work. It's an XLE Limited with every option including AWD which would be lost but I don't care about that.
A manual sienna sounds miserable. It's bad enough driving a mini van let alone having to actually be cognizant and conscious while doing so. They're the most practical thing a human can own but they're soul sucking mobiles.
Yeah clutch packs are probably cashed out.
Yup, I will take it apart and see what it looks like. Used ones are expensive, I will try my hand at rebuilding it myself. Individual friction and steel discs are available, it can't be that bad.
Eh, I am crazy, I'd rather shift it myself. Yes it is still a soul sucking vehicle, I won't be driving it much thankfully.
Bad news though, TCU and ECU are integrated as one unit. That kills my chance of swapping. I am not going to go through that much work to figure out ECU programming.
They did make the Previa with a manual trans, but those were rwd
That would be amazing, RWD would be preferred, I couldn't find any manual transmission ones for sale.
They made them supercharged too
Yea the manual got dropped when the supercharger was added. Also it was only 158 HP lol. Still a pretty classy beast.
This thing is sick=O
http://www.stanceworks.com/2017/08/the-baller-hauler-miles-shinnemans-1993-isuzu-npr-transporter/
The little details made that thing way cooler than I expected.
haha thats awesome.
First, I'll admit I don't know much about transmissions, but wouldn't it be Far Far easier to find an old automatic tranny in a junkyard from a Sienna and put that in?
Yea, used U151F transmissions are expensive though. About 1000 for a scrapyard one. I will (attempt to) rebuild the one I have.
