  4. E30 M50 tear down kinda thing
550 Posts 16 Posters 7.3k Views 2 Watching
    cool to see this motor come apart! was there something wrong with it, or did you just want to dive in? how many more miles did you put on it?
    also, the bags of cheetos are in the transmission.
    • StewCrewS
      StewCrewS
      StewCrew
      Nothing major was wrong at all man! The very first time driving it home with the swap I bottomed it out reeaally hard (with my skid plate on luckily). I live in the middle of nowhere so I should have known. But that caused the lower timing seal to drip oil. Not a lot, but still. And I honestly only put about 100 miles on it. The motor always ran strong, but it was always one thing or another with the car itself, but I definitely got to enjoy it. Anyway I figured while I'm changing the lower timing gasket, I would freshen up the rest of the motor since I've never done an actual rebuild before.
      That explains why no fluid came out of the trans... Clogged with Cheetos... (Totally kidding, the trans fluid looked great lol)
        Ever since Dan let me take a quick drive in his old car with that drivetrain I have wanted a nice shifting transmission. That thing is great!
        • StewCrewS
          StewCrewS
          StewCrew
          It really is. I can't wait to feel it with a new clutch and fresh fluid.
            StewCrew said:
            Indeed. Hey if you have someone else who wants to buy those injectors feel free to sell them. A mls head gasket is one of the last major things I need, so unfortunately that comes before injectors 😕
            Yea no worries man. I sold the first set I was looking to sell, but I still have another.
              when i offered to sell the skid plate to you and you mentioned you were going to make your own, did i make a face like 'yeah, ok'? because i feel like i would have, lol. those motors run so low in the chassis.
              only 100 miles? that thing is still low mileage!
                ^you have a 24v swap skid plate?
                  Hey stew, what are the spring rates you have on those bc's? I'm thinking about following you on those..
                  • StewCrewS
                    StewCrewS
                    StewCrew
                    Hahaha yeah, you totally did. Hindsight is 20/20... Should have bought Dan's skid plate haha.
                    They normally come 8k front/10k rear but I special ordered 10k/12k and have them set to 13 clicks up front and 15 clicks in back, it rides like a dream. However when I bought mine, there were no vendors in the US who carried bc coilovers for an e30, so I had to wait a total of like two and a half months while they made them from scratch and shipped them from Germany. Hopefully you'll have better luck than that hahah.
                      ^thats exactly what rates I was thinking. Thanks man. I'm excited to get them. If you were to do it again, would you do the same thing?
                      • Brian.B
                        Brian.B
                        Brian.
                        10K front, 12k rear? Should be the otherway around. higher spring rates in the front, lower rear. Unless stuff is Different in Subaru WRX STi's. But I doubt that.
                        instagram @howdoyoudrivethat
                        • StewCrewS
                          StewCrewS
                          StewCrew
                          Absolutely. I have rode in tons of lowered cars, but none of them were as comfy. My evo when I owned it was on the ground, and at times it felt like shit. I recommend BCs to everyone man.
                          Posted Image
                          When I was this low it rode almost as good as stock. This was also before I adjusted the front camber so the fitment was kinda meh. All of this coilover talk is making me miss driving it again lol.
                          • Brian.B
                            Brian.B
                            Brian.
                            If this thing isn't on the fucking GROUND when I see it. I'll be dissapointed in you Jake.
                              I've been doing a ton of research on this for e30's and for some reasons all of them have lower spring rates in the front. Do not know why.
                                Jake, what tire and rim setup are you using by the way? I'm thinking about doing a 15x8. I can have some decent grip and also a bit more tire to keep it cheaper. Also, are you okay with all this thread derailing? Haha
                                  My springs are 315 lb/in front 570 lb/in rear. The rear springs are stiffer because of the leverage involved in the trailing arm rear suspension design. If you go to a coilover design that relocates the spring onto the damper, then you need to reduce the rear spring rate to achieve the same balance (without doing the calculations I would estimate that I would need to go down to a 380-410 lb/in rear spring for example)
                                  A 240sx for example, typically has equal or stiffer front springs than the rear (if my memory serves me properly this morning) due to it having a multi-link rear suspension where there is little to no leverage in the suspension links that would require stiffer springs than normal.
                                  • Brian.B
                                    Brian.B
                                    Brian.
                                    No such thing on Wibimmers.
                                    • StewCrewS
                                      StewCrewS
                                      StewCrew
                                      Idunno subaru motors work sideways so who knows. The BC's come stiffer in the rear, and for the most part I thought most coilovers come stiffer in the rear? But I wanted the car to feel super tight so I got higher rates, and it definitely does.
                                      If these "m50 into e30 chasis" mounts let the motor sit ever so slightly higher, then yes, shit will be dropped. If they dont, shit will also be dropped.
                                      • Brian.B
                                        Brian.B
                                        Brian.
                                        Idk man, S13 coils are the same way, stiffer front slightly lesss stiff in the rear. I'd assume due to fat ass engines. But hey, potato.
                                        Dropped or dropped. I like it. Me too. I bottom out everywhere (my oil pan and new bumper) So I'm right along with you babe!
                                        • StewCrewS
                                          StewCrewS
                                          StewCrew
                                          Thread derailing? Not giving a fuck man :) Im hopefully helpin you out with your future setup so its all good.
                                          The sportmaxx in the pic I just uploaded were 15x8 on a 195/45 tire I believe? The car was scrapping everywhere. It was great. But I sold those and now have these:
                                          Posted Image
                                          Posted Image
                                          These are 17x7 with 20mm spacer up front (205/45) and 17x9 with 5mm spacers in back (215/45). Goodyear Eagle GT's all around. These are for cruising/meets/not drift day.
                                          I just run all spares for drift days.
                                          Posted Image
                                          \m/
